How to Copy Blu-ray 3D BD 50 to SBS 3D BD 25?
12/25/2020
Do you want to copy 3D Blu-ray to SBS 3D Blu-ray so that you can play the Blu-ray movie on a 2D Blu-ray player? DVDFab Blu-ray Copy can help you! It not only can copy Blu-ray to SBS 3D Blu-ray but also can copy BD 50 to BD 25. Now let’s have a look at how DVDFab Blu-ray Copy copies Blu-ray 3D BD 50 to SBS 3D BD 25.
How to Copy Blu-ray 3D BD 50 to SBS 3D BD 25: Step 1> Run DVDFab 11, choose Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have three modes (Full Disc, Main Movie, and Customize) to choose to copy Blu-ray 3D BD 50 to SBS 3D BD 25. Here I take Main Movie mode as an example.
How to Copy Blu-ray 3D BD 50 to SBS 3D BD 25: Step 2> Load the source.
How to Copy Blu-ray 3D BD 50 to SBS 3D BD 25: Step 3> After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and do advanced settings according to your needs. On "Advanced Settings" panel, you can choose the “Output” as BD 25 and select “Convert to Blu-ray SBS 3D” under “How to copy Blu-ray 3D”.
How to Copy Blu-ray 3D BD 50 to SBS 3D BD 25: Step 4> Navigate to the bottom of the main interface to select a directory to save the output Blu-ray: to select your optical drive as the directory from the drop-down list box is to save the output to a blank Blu-ray disc; to select a directory by clicking the "folder" icon is to save the output as a Blu-ray folder; to select a directory by clicking the "image" icon is to save the output as an ISO image file.
How to Copy Blu-ray 3D BD 50 to SBS 3D BD 25: Step 5> Click the "Start" button to start the copy process.
Note:
On Full Disc mode, you cannot choose the titles, chapters, audio tracks and subtitles but you can do advanced settings.
If you choose to save the output to a blank Blu-ray/DVD disc, you will be promoted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the copy process.
If you want to get more information about DVDFab Blu-ray Copy, please go to https://www.dvdfab.cn/blu-ray-copy.htm.
① Burn Blu-rays to blank discs or copy to HDDs as ISO files/folders
② Offer 5 different copy modes to meet versatile backup needs
③ Support all types of blank discs: BD-R, BD-RE, DVD±R and DVD±RW
④ Copy the Blu-rays in a lossless manner or compress them smaller
